跳转到主内容
加入维修社区 - 创建账户
HP Envy 23-d060qd TouchSmart Hard Drive Replacement
你所需要的
  1. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the one 13.5mm PH2 screw.
  5. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Unsnap the wire mechanism to release the hard drive.
  6. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Detach the hard drive assembly by pulling it out of the socket.
  7. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
  8. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Replace the old hard drive with your new hard drive.
结论
5等其他人完成本指南。
Zachary Dicks
于10/01/15注册
1,166 声望
创作了7篇指南
团队
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G10
4 名成员
创作了14篇指南
2指南评论
Thank you so much my hard drive is bad this is going to be a quick fix and save me money you made this for dummies I LOVE IT can u tell me when I replace the hard drive will I lose everything on my computer already such as photos,files, I have everything in office purchased on the computer ? If so is there a way not to lose anything
jessica Kramer - 回复 分享
Yes you will, unless you back them up. All your data is stored on that hard drive.
Dane Elliott-Dyson - 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 66
总计 7,938
