简介
As I was moving my computer into another room I dropped it and the screen cracked. What steps can I take to keep from having to continue to use a broken screen? I know replacing a screen is a very lengthy and delicate procedure.
你所需要的
Use your hands to unclip the plastic bezels for the DVD drive and ports.
To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
One screw to remove the DVD drive is easier and safer than removing the bezel.
Hi where can i find the Display?
Remove the nineteen 10mm T15 black screws from the edge of the computer.
Had to remove the base assembly to get at one of the screws holding the display on.
Had to disconnect speaker wires.
Also had to disconnect a number of small connections at the top of the device - webcam, microphone, etc.
Use your hands to pull the plastic bezel off of the digitizer.
If digitizer glass is shattered can this be reassembled without glass or touch screen function?
7等其他人完成本指南。
16条评论
From where can I buy the glass to replace?
i wont 5 pics please send yor number watsap or send me Offer price for HP ENVY 23-d117a glass
Thanks >>
Feras emad
00966543470171
info@fersawy.com
Feras Emad - 回复
687535-001 this is the part required
Model No HP envy 23 Delhi 0201 N.
Serial no. CZC 31443 LD kindly let me know whether it is available and please mail the details to sunitha.jijo@yahoo.com
Hi.
My touchscreen has been cracked too.
Can anyone help to direct me to somewhere to buy a replacement screen please?
frank_scullion@yahoo.co.uk
Thanks in anticipation
Hi, I am in need of the replacement glass for my HP ENVY 23 touchscreen also. It fell and cracked while in transportation. The computer is still operational but my glass screen is cracked in a about 8 places. Where can I find the glass cover for this touchscreen at a reasonable price? Reach me at : ( markmccord71801@att.net ). Thanks for the assistance.
Mark McCord - December 5th, 2018
Depends on what you think is reasonable. There are several on eBay, but there are variations in the ribbon cable configurations within the same series, which means you probably will have to disassemble to see which one you need.
Im also looking for a screen for my HP Envy Touchsmart 23se-d494 anyone know where to buy one??
glass replacement the computer still works?
Need to replace a glass for HP Envy 23-d160qd.
Availability ? Cost ?
Hola , do you know number part ?
Hi.
Can anyone help to direct me to somewhere to buy a replacement screen please? agencethaly@gmail.com
