跳转到主内容
HP Envy 23-d060qd TouchSmart Display Assembly Replacement
你所需要的
  1. HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Display: 步骤 4 中的图像 1,2 HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Display: 步骤 4 中的图像 2,2
    • Use your hands to unclip the plastic bezels for the DVD drive and ports.
    • To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
    • You may want to lay the computer face down, on a flat, clean surface to ensure nothing falls out when disassembling the computer for next steps.
  5. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the nineteen 10mm T15 black screws from the edge of the computer.
    • Lay the computer on its front when preforming this step, and leave it face down for the rest of the guide.
  6. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Lift up the computer by the base very slowly, and disconnect the three wired connections to the display with your hands. Always disconnect wired connections from the plastic base.
  7. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Set the computer aside, and use a small knife to cut the strips attaching the display to the digitizer.
  8. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Use a plastic spudger to unclip the 3 ribbon clips on the back of the display.
  9. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the four 7mm T15 silver screws from the edge of the computer.
  10. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 10 中的图像 1,1
    • Gently pull the display free from the digitizer with your hands.
  11. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 11 中的图像 1,2 HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Remove the four 17.5mm T15 screws from the speakers.
    • When the speakers are free, use your hands to pull them free from the digitizer.
  12. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the three 10mm T15 screws from bezel.
  13. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: 步骤 13 中的图像 1,1
    • Use your hands to pull the plastic bezel off of the digitizer.
结论
7等其他人完成本指南。
Zachary Dicks
于10/01/15注册
1,166 声望
创作了7篇指南
团队
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G10
4 名成员
创作了14篇指南
17指南评论
On step 5 you've to remove also the 4 silver screw that keep display to the mainboard chassis.
illola - 回复
From where can I buy the glass to replace?
Aram Vardanyan - 回复
i wont 5 pics please send yor number watsap or send me Offer price for HP ENVY 23-d117a glass
Thanks >>
Feras emad
00966543470171
info@fersawy.com
Feras Emad - 回复
687535-001 this is the part required
Model No HP envy 23 Delhi 0201 N.
Serial no. CZC 31443 LD kindly let me know whether it is available and please mail the details to sunitha.jijo@yahoo.com
Sunitha.jijo@yahoo.com - 回复
Hi.
My touchscreen has been cracked too.
Can anyone help to direct me to somewhere to buy a replacement screen please?
frank_scullion@yahoo.co.uk
Thanks in anticipation
Frank Scullion - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 50
总计 14,902
