跳转到主内容
HP Envy 17m-ae111dx Battery Replacement
你所需要的
  1. HP Envy 17m-ae111dx Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx Battery Replacement: 步骤 2 中的图像 1,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 2 中的图像 2,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx Battery Replacement: 步骤 3 中的图像 1,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 3 中的图像 2,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 3 中的图像 3,3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx Battery Replacement: 步骤 4 中的图像 1,2 HP Envy 17m-ae111dx Battery Replacement: 步骤 4 中的图像 2,2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx Battery Replacement: 步骤 5 中的图像 1,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 5 中的图像 2,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 5 中的图像 3,3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove all seven screws.
  7. HP Envy 17m-ae111dx Battery Replacement: 步骤 7 中的图像 1,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 7 中的图像 2,3 HP Envy 17m-ae111dx Battery Replacement: 步骤 7 中的图像 3,3
    • Unplug the battery from the connection port and remove the battery from the device.
结论
3等其他人完成本指南。
一条评论
These instructions were also applicable to an HP 17ar050 Pavillion Laptop.
George Willis - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 30
总计 3,782
