跳转到主内容
HP Envy 17-J013CL WLAN Module Replacement
你所需要的
  1. HP Envy 17-J013CL WLAN Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL WLAN Module Replacement: 步骤 2 中的图像 1,1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL WLAN Module Replacement: 步骤 3 中的图像 1,3 HP Envy 17-J013CL WLAN Module Replacement: 步骤 3 中的图像 2,3 HP Envy 17-J013CL WLAN Module Replacement: 步骤 3 中的图像 3,3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL WLAN Module Replacement, Back Panel: 步骤 4 中的图像 1,2 HP Envy 17-J013CL WLAN Module Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL WLAN Module Replacement: 步骤 5 中的图像 1,1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL WLAN Module Replacement, WLAN Module: 步骤 6 中的图像 1,2 HP Envy 17-J013CL WLAN Module Replacement, WLAN Module: 步骤 6 中的图像 2,2
    • Locate the WLAN module.
  7. HP Envy 17-J013CL WLAN Module Replacement: 步骤 7 中的图像 1,2 HP Envy 17-J013CL WLAN Module Replacement: 步骤 7 中的图像 2,2
    • Use a PH1-screwdriver to remove the 7mm screw from the motherboard.
  8. HP Envy 17-J013CL WLAN Module Replacement: 步骤 8 中的图像 1,2 HP Envy 17-J013CL WLAN Module Replacement: 步骤 8 中的图像 2,2
    • Lift the black and white wire from the module. Removing the wires from the ends will have a distinct popping noise.
    • Remember to put the white wire on the left side of the module and the black wire on the right side. Failure to do so may cause issues.
  9. HP Envy 17-J013CL WLAN Module Replacement: 步骤 9 中的图像 1,2 HP Envy 17-J013CL WLAN Module Replacement: 步骤 9 中的图像 2,2
    • Gently pull out the module away from the motherboard.
    • Make sure to put the module back in the correct orientation designated by the little arch in the end of the module.
结论
另外一个人完成了本指南。
Matt McBride
于02/02/17注册
845 声望
创作了6篇指南
团队
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 354
