跳转到主内容
HP Envy 17-J013CL Motherboard Replacement
你所需要的
  1. HP Envy 17-J013CL Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Motherboard Replacement: 步骤 2 中的图像 1,1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Motherboard Replacement: 步骤 3 中的图像 1,3 HP Envy 17-J013CL Motherboard Replacement: 步骤 3 中的图像 2,3 HP Envy 17-J013CL Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Motherboard Replacement, Back Panel: 步骤 4 中的图像 1,2 HP Envy 17-J013CL Motherboard Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Motherboard Replacement, Processor: 步骤 6 中的图像 1,3 HP Envy 17-J013CL Motherboard Replacement, Processor: 步骤 6 中的图像 2,3 HP Envy 17-J013CL Motherboard Replacement, Processor: 步骤 6 中的图像 3,3
    • Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
    • Remove the screw with a PH1-screwdriver to release the CD-drive.
  7. HP Envy 17-J013CL Motherboard Replacement: 步骤 7 中的图像 1,3 HP Envy 17-J013CL Motherboard Replacement: 步骤 7 中的图像 2,3 HP Envy 17-J013CL Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use a PH1-Screwdriver to remove all the 7mm screws.
    • Use a PH0-Screwdriver to remove the 3mm screws.
    • Use the same PH0-Screwdriver for the 2mm screws.
  8. HP Envy 17-J013CL Motherboard Replacement: 步骤 8 中的图像 1,2 HP Envy 17-J013CL Motherboard Replacement: 步骤 8 中的图像 2,2
    • Pull the under panel from the laptop by pulling at the edges once all screws are removed. Gently lift it off and place to the side.
  9. HP Envy 17-J013CL Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unscrew the coiled springs indicated in red from the the motherboard.
    • Remove the 7mm screws with a PH1-screwdriver to loosen the fan.
    • Unplug the fan from the motherboard.
  10. HP Envy 17-J013CL Motherboard Replacement: 步骤 10 中的图像 1,1
    • Lift the fan out and then lift out the black grill covering the processor.
  11. HP Envy 17-J013CL Motherboard Replacement: 步骤 11 中的图像 1,2 HP Envy 17-J013CL Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a Flathead screwdriver to turn the screw 180 degrees to unlock the processor from the motherboard.
    • Gently and vertically lift the processor out.
    • When placing the processor chip back in, make sure the golden triangle is on the top-left corner of the motherboard slot.
    • Be careful not to bend the pins on the processor chip. Broken pins will render the chip useless.
  12. HP Envy 17-J013CL Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove the 7mm screws holding down the motherboard to the frame.
  13. HP Envy 17-J013CL Motherboard Replacement: 步骤 13 中的图像 1,2 HP Envy 17-J013CL Motherboard Replacement: 步骤 13 中的图像 2,2
    • Locate the two bottom cables and lift up the black secure tabs.
    • Grab the cables by the translucent tabs and gently pull them out of the motherboard.
  14. HP Envy 17-J013CL Motherboard Replacement: 步骤 14 中的图像 1,1
    • On the left side of the motherboard, remove the two cables by first lifting the black secure tabs and using the translucent tabs to pull them out.
  15. HP Envy 17-J013CL Motherboard Replacement: 步骤 15 中的图像 1,1
    • Next to the WLAN, remove the two plugs indicated in red from the motherboard.
    • Be gentle when removing these two as too much stress can tear the cables from the plug.
    • Remove the flat cable from the motherboard by first lifting the securing black tab and pulling it out.
  16. HP Envy 17-J013CL Motherboard Replacement: 步骤 16 中的图像 1,2 HP Envy 17-J013CL Motherboard Replacement: 步骤 16 中的图像 2,2
    • Where the CPU fan was, lift the securing tabs on the cables and extract them from the motherboard.
  17. HP Envy 17-J013CL Motherboard Replacement: 步骤 17 中的图像 1,1
    • Gently lift the motherboard from the laptop housing and pulling to the left.
结论
4等其他人完成本指南。
Matt McBride
于02/02/17注册
845 声望
创作了6篇指南
团队
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G6
3 名成员
创作了6篇指南
一条评论
What is the proper name of the housing that the motherboard sets in? I need to order one of these because all the hinge plastic is broken.
TIA
Jim
jsryhstymryuberJames Abt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 3,119
