跳转到主内容
HP Envy 17-J013CL Memory Module Replacement
你所需要的
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: 步骤 2 中的图像 1,1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: 步骤 3 中的图像 1,3 HP Envy 17-J013CL Memory Module Replacement: 步骤 3 中的图像 2,3 HP Envy 17-J013CL Memory Module Replacement: 步骤 3 中的图像 3,3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: 步骤 4 中的图像 1,2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: 步骤 5 中的图像 1,1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: 步骤 6 中的图像 1,2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: 步骤 6 中的图像 2,2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: 步骤 7 中的图像 1,2 HP Envy 17-J013CL Memory Module Replacement: 步骤 7 中的图像 2,2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: 步骤 8 中的图像 1,2 HP Envy 17-J013CL Memory Module Replacement: 步骤 8 中的图像 2,2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
结论
另外一个人完成了本指南。
Matt McBride
于02/02/17注册
899 声望
创作了6篇指南
团队
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G6
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 799
