跳转到主内容
HP Envy 17-J013CL Battery Replacement
你所需要的
  1. HP Envy 17-J013CL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: 步骤 2 中的图像 1,1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: 步骤 3 中的图像 1,3 HP Envy 17-J013CL Battery Replacement: 步骤 3 中的图像 2,3 HP Envy 17-J013CL Battery Replacement: 步骤 3 中的图像 3,3
    • Pull the battery out and let go of the battery slider.
结论
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
2等其他人完成本指南。
Matt McBride
于02/02/17注册
845 声望
创作了6篇指南
团队
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G6
3 名成员
创作了6篇指南
一条评论
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,996
