当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before you begin taking apart the computer, make sure that it is completely powered off.
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Unscrew 4.5mm Phillips screw.
Unplug both antenna connectors by carefully pulling them upwards.
During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
