跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
A wireless card gives your laptop access to the internet, therefore it is one of the most important components for many. If the wireless card fails use this guide to replace it in your HP Envy 17-3070NR.
配件
没有特定配件。
  1. Before you begin taking apart the computer, make sure that it is completely powered off. Slide the release latch away from the nearest edge.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. Remove the six 3.7mm Phillips screws. Slide the back cover until it clicks, then lift it straight off. Slide the back cover until it clicks, then lift it straight off.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Unscrew 4.5mm Phillips screw. Unplug both antenna connectors by carefully pulling them upwards. During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
    • Unscrew 4.5mm Phillips screw.
    • Unplug both antenna connectors by carefully pulling them upwards.
    • During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
  5. Pull wireless card up and away from you. Pull wireless card up and away from you. Pull wireless card up and away from you.
    • Pull wireless card up and away from you.
结论
Jasper Lewin
于2015年04月21日注册
720 信誉积分
创作了6篇指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 13
总计 496
