当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before you begin taking apart the computer, make sure that it is completely powered off.
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
Remove the hard drive by lifting it out of its cavity.
Unplug the hard drive cable that connects it to the main assembly.
Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
Remove the battery by pulling it straight out away from the computer.
It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
Remove the subwoofer by pulling straight up from the main assembly.
Remove the seventeen 6.6mm Phillips screws.
Remove the three 3.6 mm Phillips screws.
Remove the eleven 3.2mm Phillips screws
Three of the 3.2mm Phillips screws are located underneath the black hard drive flap.
Make sure that you keep the screws organized so that you keep track of all of the different sizes and locations.
Flip the laptop over.
Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly.
Starting location for prying does not matter as long as you pry all around the frame before lifting it off.
Do not fully lift the top cover because there are cables that will need to be disconnected before removal.
Gently pull the black connector towards you to disconnect the top cover from the main assembly.
Once both connectors are disconnected, lift the top cover off of the main assembly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
