你所需要的
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
Remove the hard drive by lifting it out of its cavity.
Unplug the hard drive cable that connects it to the main assembly.
Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
Remove the subwoofer by pulling straight up from the main assembly.
Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
