跳转到主内容
HP Envy 17-3070NR Subwoofer Replacement
你所需要的
  1. HP Envy 17-3070NR Subwoofer Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Envy 17-3070NR Subwoofer Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Subwoofer Replacement: 步骤 2 中的图像 1,3 HP Envy 17-3070NR Subwoofer Replacement: 步骤 2 中的图像 2,3 HP Envy 17-3070NR Subwoofer Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 步骤 3 中的图像 1,3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 步骤 3 中的图像 2,3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 步骤 3 中的图像 3,3
    • Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
    • Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
    • Remove the subwoofer by pulling straight up from the main assembly.
结论
Abby Lentz
于04/21/15注册
586 声望
创作了4篇指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 513
