跳转到主内容
HP Envy 17-3070NR Optical Drive Replacement
你所需要的
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: 步骤 2 中的图像 1,3 HP Envy 17-3070NR Optical Drive Replacement: 步骤 2 中的图像 2,3 HP Envy 17-3070NR Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 2,3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 3,3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: 步骤 5 中的图像 1,3 HP Envy 17-3070NR Optical Drive Replacement: 步骤 5 中的图像 2,3 HP Envy 17-3070NR Optical Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
结论
Jon Fuson
于04/21/15注册
140 声望
撰写一个指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,205
