跳转到主内容
HP Envy 17-3070NR Hard Drive Replacement
你所需要的
  1. HP Envy 17-3070NR Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Envy 17-3070NR Hard Drive Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Envy 17-3070NR Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Envy 17-3070NR Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
    • Remove the hard drive by lifting it out of its cavity.
    • Unplug the hard drive cable that connects it to the main assembly.
结论
另外一个人完成了本指南。
Jasper Lewin
于04/21/15注册
750 声望
创作了6篇指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 4,529
