当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before you begin taking apart the computer, make sure that it is completely powered off.
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
Remove the battery by pulling it straight out away from the computer.
It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
