跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
HP Envy 17-3070NR Battery Replacement
你所需要的
  1. HP Envy 17-3070NR Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Envy 17-3070NR Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Battery Replacement: 步骤 2 中的图像 1,3 HP Envy 17-3070NR Battery Replacement: 步骤 2 中的图像 2,3 HP Envy 17-3070NR Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Battery Replacement, Battery: 步骤 3 中的图像 1,2 HP Envy 17-3070NR Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  4. HP Envy 17-3070NR Battery Replacement: 步骤 4 中的图像 1,3 HP Envy 17-3070NR Battery Replacement: 步骤 4 中的图像 2,3 HP Envy 17-3070NR Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
结论
5等其他人完成本指南。
Abby Lentz
于04/21/15注册
586 声望
创作了4篇指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 8,770
