跳转到主内容
修复你的物品
维修的权力
商店
简介
Batteries go bad with time. If you find yourself having to charge your HP Envy 17-3070NR too often or it would not store charge at all, this guide is for you.
  1. Before you begin taking apart the computer, make sure that it is completely powered off. Slide the release latch away from the nearest edge.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. Remove the six 3.7mm Phillips screws. Slide the back cover until it clicks, then lift it straight off. Slide the back cover until it clicks, then lift it straight off.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  4. Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it. Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  5. Remove the two 3.8 mm Torx screws using M8 Torx screwdriver. Remove the battery by pulling it straight out away from the computer. It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
结论
5等其他人完成本指南。
Abby Lentz
于2015年04月21日注册
554 信誉积分
创作了4篇指南
团队
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G8
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 10
过去的30天: 35
总计 7,586
