本指南有最近更改,您可查看未经巡查的最新版本。
简介
This 2-step instruction guides the users to replace the back cover of HP Envy 17-3070NR. In order to fix the hardware inside the laptop, it is very important to remove its back cover first. The instruction can be further used for RAM replacement, subwoofer replacement, and battery replacement for this computer model.
Before taking apart the computer, make sure to power off your computer completely and disconnect from any external power source. In step two of this guide, you will need a Phillips #2 screwdriver to remove six 3.7mm screws.
你所需要的
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
2等其他人完成本指南。
