跳转到主内容
HP Envy 15-u001dx Screen Replacement
你所需要的
  1. HP Envy 15-u001dx Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
    • If these screws are not removed and you separate the bottom portion of the screen, you will not be able to refasten the screen to the back because the screw tab will break.
  2. HP Envy 15-u001dx Screen Replacement: 步骤 2 中的图像 1,2 HP Envy 15-u001dx Screen Replacement: 步骤 2 中的图像 2,2
    • Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
  3. HP Envy 15-u001dx Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the two 2.5 mm Phillips #0 screws with a Phillips#0 Screwdriver.
  4. HP Envy 15-u001dx Screen Replacement: 步骤 4 中的图像 1,1
    • Detach the webcam from the damaged screen using spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. HP Envy 15-u001dx Screen Replacement: 步骤 5 中的图像 1,1
    • Gently detach small white connector with spudger.
  6. HP Envy 15-u001dx Screen Replacement: 步骤 6 中的图像 1,1
    • Gently remove the tape with the wire to completely separate the screen.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 的会员
USFT-LACY-F16S9G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,567
