跳转到主内容
HP Envy 15-u001dx Cooling Fan Replacement
你所需要的
  1. HP Envy 15-u001dx Cooling Fan Replacement, HP Envy 15-u001dx Disassembly: 步骤 1 中的图像 1,1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Cooling Fan Replacement: 步骤 5 中的图像 1,2 HP Envy 15-u001dx Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: 步骤 6 中的图像 1,2 HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: 步骤 6 中的图像 2,2
    • Remove the three 4.5 mm Phillips #0 screws holding the fan in place.
  7. HP Envy 15-u001dx Cooling Fan Replacement: 步骤 7 中的图像 1,1
    • Gently detach the connector with a spudger and the fan is free to be removed.
结论
5等其他人完成本指南。
Dakota Presley
于10/05/16注册
885 声望
创作了6篇指南
团队
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 的会员
USFT-LACY-F16S9G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,316
