跳转到主内容
HP Elitebook x360 1040 G5 Touchpad Replacement
你所需要的
  1. HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: 步骤 1 中的图像 1,2 HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 2 中的图像 1,2 HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: 步骤 3 中的图像 1,2 HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: 步骤 3 中的图像 2,2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 4 中的图像 1,3 HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 4 中的图像 2,3 HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: 步骤 5 中的图像 1,2 HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: 步骤 5 中的图像 2,2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
  6. HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 6 中的图像 1,3 HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 6 中的图像 2,3 HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 6 中的图像 3,3
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the left hand side.
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the right hand side.
  7. HP Elitebook x360 1040 G5 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Gently pull up on the top two corners of the touchpad and remove it from the laptop.
结论
另外一个人完成了本指南。
Corey Agena
于04/21/19注册
833 声望
创作了6篇指南
团队
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 688
