简介
If the screen on your laptop has cracks in it or if the screen no longer comes on, chances are it needs replaced. This guide is designed to help users successfully remove the screen on the HP Elitebook x360 1040 G5 for replacement. Minimal tools are required; however caution should be executed when using a heat gun. Using this tool improperly can cause serious burns, damage to your electronics and possibly start a fire. Make certain that you’ve read and understand the manufacturer provided instructions before attempting to use this tool.
你所需要的
Open your laptop.
Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
Continue to apply heat for 5 to 10 minutes.
另外一个人完成了本指南。
