跳转到主内容
HP Elitebook x360 1040 G5 Screen display Replacement
你所需要的
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 步骤 1 中的图像 1,3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 步骤 1 中的图像 2,3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 步骤 1 中的图像 3,3
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 2 中的图像 1,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 2 中的图像 2,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 2 中的图像 3,3
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 3 中的图像 1,2 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 4 中的图像 1,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 4 中的图像 2,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 5 中的图像 1,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 5 中的图像 2,3 HP Elitebook x360 1040 G5 Screen display Replacement: 步骤 5 中的图像 3,3
    • Remove the screen from the laptop.
结论
另外一个人完成了本指南。
Tyler A Cobb
于09/03/19注册
321 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Hovde Fall 2019 IUPUI, Team S1-G1, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 1,464
