跳转到主内容
HP Elitebook x360 1040 G5 Motherboard Replacement
你所需要的
  1. HP Elitebook x360 1040 G5 Motherboard Replacement, Lower Case: 步骤 1 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 2 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 4 中的图像 1,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 4 中的图像 2,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • With the battery removed, begin by removing the two coaxial connectors located near the hinge using an ESD-safe spudger.
    • To do this, slide the tip of the spudger under the wire until it is snug against the connector. Then, pry straight up from the board.
  6. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 6 中的图像 1,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 6 中的图像 2,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the three white and two brown ribbon cables located on the bottom of the motherboard.
    • Use a spudger to carefully push on each side of the connector in order to release the cable.
  7. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 7 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove sliding connector located near the bottom right corner of the motherboard.
    • Gently push on each side of the connector using a spudger until it is free.
  8. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 8 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the foil protector from the right side of the motherboard by gently peeling it back with the opening tool.
    • Remove the ribbon connector underneath using the spudger.
  9. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 9 中的图像 1,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 9 中的图像 2,3 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the two flat connectors located on both sides of the motherboard near the fans.
    • Gently pry the connector straight up from the motherboard using a spudger or opening tool.
  10. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 10 中的图像 1,2 HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the five M2 X 3mm screws from the perimeter of the motherboard using the Phillips #1 screwdriver.
    • Remove the two M2 X 5mm screws from the upper corners of the motherboard using the Phillips #1 screwdriver.
    • Finally, remove the two interior M2 X 3mm screws from the motherboard's cooling system.
  11. HP Elitebook x360 1040 G5 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard carefully from the computer shell. The motherboard can now be replaced.
结论
另外一个人完成了本指南。
Tyler A Cobb
于09/03/19注册
321 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Hovde Fall 2019 IUPUI, Team S1-G1, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G1
3 名成员
创作了4篇指南
一条评论
Hi! I think you should also mention that there is a sim-card slot dummy holding a motherbord, you can not lift it when a holder or a dummy is inside. it should be poked out with a pincer through the hole one the side of a motherboard above the slot itself (it do not eject on a spring like a normal sim card holder)
Сергей Соколов - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 38
总计 1,601
