跳转到主内容
HP Elitebook x360 1030 G2 Battery Replacement
你所需要的
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: 步骤 2 中的图像 1,2 HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: 步骤 2 中的图像 2,2
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Max Kletskov
于04/22/20注册
40,850 声望
创作了16篇指南
团队
The Home Depot The Home Depot 的会员
Community
18,087 名成员
创作了140篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 41
过去 30 天: 150
总计 5,476
