跳转到主内容
HP Elitebook Folio 9470m Trackpad Replacement
你所需要的
  1. HP Elitebook Folio 9470m Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 2 中的图像 1,1
    • In the center of the laptop slide the black piece back till it turns red indicating it is unlocked and the battery can be removed.
  3. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 3 中的图像 1,2 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 3 中的图像 2,2
    • Remove the 2 Phillips head screws that attach the cover on the left.
  4. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 4 中的图像 1,3 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 4 中的图像 2,3 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 4 中的图像 3,3
    • Remove the 4 Phillips screws holding the hard drive in place
    • Remove by gently prying and pulling up on the tab and out.
  5. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 5 中的图像 1,3 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 5 中的图像 2,3 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 5 中的图像 3,3
    • Remove the 3 Phillips head screws holding the back plate in.
    • Gently pull up and out to remove plate.
  6. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 6 中的图像 1,2 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 6 中的图像 2,2
    • Remove all eighteen screws marked M2x3 and M2x5.
    • Remove the remaining four Phillips head screws.
  7. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 7 中的图像 1,2 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 7 中的图像 2,2
    • Slowly pry and lift the frame up while checking for connected wires and ribbons that may be obstructing it.
  8. HP Elitebook Folio 9470m Trackpad Replacement: 步骤 8 中的图像 1,2 HP Elitebook Folio 9470m Trackpad Replacement: 步骤 8 中的图像 2,2
    • Detach ribbon wires by gently lifting the grey flap and pulling them out.
    • Do not pull hard on the wires.
    • Push the track pad from the bottom and it should come right out.
结论
另外一个人完成了本指南。
Kenneth Bowers
于04/08/16注册
1,381 声望
创作了7篇指南
团队
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S1G1
4 名成员
创作了19篇指南
一条评论
Please make sure the Track Pad is not "turned off:" (HP Folio has a Track Pad on/off feature by double-tap in upper left hand corner)
1) Double tap the upper left corner of the Track Pad by the Amber LED
2a) If the LED is "On" then the Track Pad is "Off"
2b) If the LED is "Off" then the Track Pad is "On"
nemisonic - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 3,785
