跳转到主内容
HP Elitebook Folio 9470m Keyboard Replacement
你所需要的
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 2 中的图像 1,2 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 3 中的图像 1,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 3 中的图像 2,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 3 中的图像 3,3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 4 中的图像 1,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 4 中的图像 2,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 4 中的图像 3,3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 6 中的图像 1,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 6 中的图像 2,3 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 6 中的图像 3,3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: 步骤 7 中的图像 1,2 HP Elitebook Folio 9470m Keyboard Replacement: 步骤 7 中的图像 2,2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
结论
另外一个人完成了本指南。
Kenneth Bowers
于04/08/16注册
1,381 声望
创作了7篇指南
团队
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S1G1
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 55
总计 5,321
