跳转到主内容
HP Elitebook 8570w Optical Drive Replacement
你所需要的
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: 步骤 4 中的图像 1,2 HP Elitebook 8570w Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
结论
MJ Routh
于11/06/17注册
465 声望
创作了3篇指南
团队
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 1,761
