简介
This replacement guide will help you disconnect the hard drive from your HP EliteBook 8570w in order to replace it with a new/different hard drive. It consists of 6 relatively easy steps that should guide you successfully.
你所需要的
To begin, you will need to remove the battery by sliding the left slider (red) to the left.
Push the battery away from you to release it.
Then, use the right slider to remove the computer's backing (shown in image)
Slide the backing towards you to remove it.
5等其他人完成本指南。
