跳转到主内容
HP Elitebook 8570w Hard Drive Replacement
你所需要的
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: 步骤 3 中的图像 1,1
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: 步骤 5 中的图像 1,1
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: 步骤 6 中的图像 1,1
    • The hard drive can now be replaced inside the caddy.
结论
5等其他人完成本指南。
MJ Routh
于11/06/17注册
465 声望
创作了3篇指南
团队
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 54
总计 14,445
