跳转到主内容
HP Elitebook 8460p Optical Drive Replacement
你所需要的
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: 步骤 3 中的图像 1,1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 2,3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: 步骤 6 中的图像 1,2 HP Elitebook 8460p Optical Drive Replacement: 步骤 6 中的图像 2,2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: 步骤 7 中的图像 1,3 HP Elitebook 8460p Optical Drive Replacement: 步骤 7 中的图像 2,3 HP Elitebook 8460p Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: 步骤 8 中的图像 1,3 HP Elitebook 8460p Optical Drive Replacement: 步骤 8 中的图像 2,3 HP Elitebook 8460p Optical Drive Replacement: 步骤 8 中的图像 3,3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 14
总计 1,030
