跳转到主内容
HP Elitebook 840 G1 RAM Replacement
你所需要的
  1. HP Elitebook 840 G1 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
  2. HP Elitebook 840 G1 RAM Replacement: 步骤 2 中的图像 1,1
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 RAM Replacement: 步骤 3 中的图像 1,1
    • Battery should easily be lifted up and out.
  4. HP Elitebook 840 G1 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Identify the RAM and the pull tabs that will be used in the next step.
    • Always use an anti-static wrist strap when working on a computer.
  5. HP Elitebook 840 G1 RAM Replacement: 步骤 5 中的图像 1,1
    • Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
    • When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  6. HP Elitebook 840 G1 RAM Replacement: 步骤 6 中的图像 1,1
    • Pull the RAM stick gently out and up once the tabs have been pulled to the side.
结论
8等其他人完成本指南。
Ashley Williams
于08/27/15注册
2,419 声望
创作了5篇指南
团队
USF Tampa, Team 5-3, Blackwell Fall 2015 USF Tampa, Team 5-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G3
4 名成员
创作了19篇指南
一条评论
Bonjour,
Ce tuto est clair, merci ! :)
christophe.ducard - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 46
总计 9,039
