跳转到主内容
修复你的物品
维修的权力
商店
简介
Replace dead or dying battery to solve for laptop powering off right away or quickly when unplugged
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
  2. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  3. Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  4. Battery should easily be lifted up and out.
    • Battery should easily be lifted up and out.
结论
22等其他人完成本指南。
Ashley Williams
于2015年08月27日注册
2,131 信誉积分
创作了5篇指南
团队
USF Tampa, Team 5-3, Blackwell Fall 2015 USF Tampa, Team 5-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G3
4 名成员
创作了17篇指南
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
Vikshay Vuthavadoo - 回复
添加评论
浏览统计数据:
过去的24小时: 24
过去的7天: 170
过去的30天: 762
总计 53,466
