简介
Perhaps the keyboard has been damaged or the layout is wrong?
In that case you need to replace the top cover.
你所需要的
Flip the notebook.
Unscrew the screws.
Open the base enclosure using a plastic wedge (a credit card might also work). Follow the direction of the green arrows.
Detach the battery using a plastic spudger.
Unscrew the battery screws. Be aware not to damage the speaker cables.
Now remove the CMOS battery. Beware: it is glued to the enclosure. So remove with care.
Remove the SIM slot.
Now detach all connections with the mother board (using a plastic spudger). Unscrew the black (mostly flat) screws until the mother board is loose.
Put the Display Cables to the top side. In that way the cables aren't damaged when removing the top cover.
Remove the loose plastic parts on the motherboard.
Detach the mother board.
Unscrew all the remaining components from the top cover.
Unscrew the black screws in the top corners until you can separate the top cover and the display.
Attach the new Top Cover.
Follow the previous steps in reverse order.
Beware when closing the Base Enclosure: slide it towards the front at a 30 degree angle until it snaps in place. Screw everything back together. In this way you prevent an open gap at the front side.
To replace the top cover/keyboard, the device needs to be completely disassembled. That takes time but is not that difficult.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
Marelec IT正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
