跳转到主内容
HP Elitebook 820 G1 Keyboard Replacement
你所需要的
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: 步骤 7 中的图像 1,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 7 中的图像 2,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 7 中的图像 3,3
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: 步骤 9 中的图像 1,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 9 中的图像 2,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: 步骤 10 中的图像 1,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 10 中的图像 2,3 HP Elitebook 820 G1 Keyboard Replacement: 步骤 10 中的图像 3,3
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove the keyboard from the housing.
结论
4等其他人完成本指南。
Lauren Vance
于10/31/18注册
388 声望
创作了2篇指南
团队
IUPUI, Team S1-G2, Harley Fall 2018 IUPUI, Team S1-G2, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S1G2
2 名成员
创作了4篇指南
一条评论
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 51
总计 11,072
