跳转到主内容
HP Elitebook 820 G1 Hard Drive Replacement
你所需要的
  1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive casing.
    • Unscrew the four 8mm Philips screws holding the hard drive.
  7. HP Elitebook 820 G1 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive from the casing and replace it.
结论
3等其他人完成本指南。
团队
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 3,838
