跳转到主内容
HP Elitebook 820 G1 Battery Replacement
你所需要的
  1. HP Elitebook 820 G1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Battery Replacement: 步骤 3 中的图像 1,1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift and remove the battery.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 51
总计 11,583
