跳转到主内容
HP Elitebook 6930p RAM (Expansion Slot) Replacement
你所需要的
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 步骤 1 中的图像 1,3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 步骤 1 中的图像 2,3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 步骤 2 中的图像 1,2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 步骤 2 中的图像 2,2
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: 步骤 3 中的图像 1,2 HP Elitebook 6930p RAM (Expansion Slot) Replacement: 步骤 3 中的图像 2,2
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
结论
8等其他人完成本指南。
Richdave
于04/09/10注册
32,063 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
17条评论
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - 回复
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - 回复
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - 回复
Thank you for information.
By p8slot.com
sutep Fifa - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 33
总计 15,520
