跳转到主内容
HP EliteOne 800 G1 RAM Replacement
  1. HP EliteOne 800 G1 RAM Replacement, Removing the Back Cover: 步骤 1 中的图像 1,3 HP EliteOne 800 G1 RAM Replacement, Removing the Back Cover: 步骤 1 中的图像 2,3 HP EliteOne 800 G1 RAM Replacement, Removing the Back Cover: 步骤 1 中的图像 3,3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 RAM Replacement, RAM: 步骤 2 中的图像 1,2 HP EliteOne 800 G1 RAM Replacement, RAM: 步骤 2 中的图像 2,2
    • Notice the 2 latches on either side of the RAM stick.
    • Press latches outward and RAM stick will flip up to about a 30 degree angle.
  3. HP EliteOne 800 G1 RAM Replacement: 步骤 3 中的图像 1,1
    • Gently pull the RAM stick up at an angle. You may need to wiggle the stick up and down or side to side in order to get it loose.
  4. HP EliteOne 800 G1 RAM Replacement: 步骤 4 中的图像 1,2 HP EliteOne 800 G1 RAM Replacement: 步骤 4 中的图像 2,2
    • When replacing the RAM stick, take note of where the small notch on the stick is and where there is a similar notch on the slot. Make sure you position the new stick so that the notches line up.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G24
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 27
总计 2,893
