跳转到主内容
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
你所需要的
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 步骤 1 中的图像 1,3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 步骤 1 中的图像 2,3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 步骤 1 中的图像 3,3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 步骤 2 中的图像 1,3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 步骤 2 中的图像 2,3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 步骤 2 中的图像 3,3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 步骤 3 中的图像 1,2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 步骤 3 中的图像 2,2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G24
4 名成员
创作了14篇指南
2条评论
where can i buy a replace cage for the hard drive?
Thomas Dickson - 回复
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 21
过去 30 天: 55
总计 8,366
