跳转到主内容
HP EliteBook x360 830 G7 Touchpad Removal
你所需要的
  1. HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 步骤 1 中的图像 1,3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 步骤 1 中的图像 2,3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: 步骤 1 中的图像 3,3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Touchpad Removal, Disconnect the bundled cable connector: 步骤 2 中的图像 1,1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: 步骤 3 中的图像 2,2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: 步骤 4 中的图像 1,2 HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: 步骤 4 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: 步骤 5 中的图像 3,3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: 步骤 6 中的图像 1,2 HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: 步骤 6 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the six 2 mm screws holding the touchpad in place.
  7. HP EliteBook x360 830 G7 Touchpad Removal: 步骤 7 中的图像 1,2 HP EliteBook x360 830 G7 Touchpad Removal: 步骤 7 中的图像 2,2
    • Use a spudger or a clean fingernail to flip up the locking flap on the motherboard.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the tab.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  8. HP EliteBook x360 830 G7 Touchpad Removal: 步骤 8 中的图像 1,2 HP EliteBook x360 830 G7 Touchpad Removal: 步骤 8 中的图像 2,2
    • Use an opening tool or spudger to lift the metal bracket with the touchpad off of the laptop.
    • Remove the old touchpad.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alec Aviles
于02/08/24注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 15
总计 44
