跳转到主内容
HP EliteBook x360 830 G7 Speakers Replacement
你所需要的
  1. HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 步骤 1 中的图像 1,3 HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 步骤 1 中的图像 2,3 HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 步骤 1 中的图像 3,3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Speakers Replacement, Disconnect the bundled cable connector: 步骤 2 中的图像 1,1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Speakers Replacement, Peel the copper foil tape: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G7 Speakers Replacement, Peel the copper foil tape: 步骤 3 中的图像 2,2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Speakers Replacement, Remove the screws: 步骤 4 中的图像 1,2 HP EliteBook x360 830 G7 Speakers Replacement, Remove the screws: 步骤 4 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Speakers Replacement, Speakers: 步骤 6 中的图像 1,2 HP EliteBook x360 830 G7 Speakers Replacement, Speakers: 步骤 6 中的图像 2,2
    • Gently pinch the white tab and pull the speaker cable out of its socket.
    • Don't pull on the cables.
    • If you can't get the speaker cable out by hand, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  7. HP EliteBook x360 830 G7 Speakers Replacement: 步骤 7 中的图像 1,1
    • Remove the right and left speakers from the laptop.
    • There is a wire connecting the two speakers that is still attached to the laptop, so do not pull the speakers apart or away from the device.
    • Disconnect the speaker wire from the wire hooks along the edge of the chassis.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jaila Crum
于09/12/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 28
