跳转到主内容
HP EliteBook x360 830 G7 RAM Replacement
你所需要的
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: 步骤 1 中的图像 1,2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: 步骤 1 中的图像 2,2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 步骤 2 中的图像 1,3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 步骤 2 中的图像 2,3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 步骤 2 中的图像 3,3
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: 步骤 3 中的图像 1,1
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 83
总计 964
