跳转到主内容
HP EliteBook x360 830 G7 Fan Replacement
你所需要的
  1. HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 步骤 1 中的图像 1,3 HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 步骤 1 中的图像 2,3 HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 步骤 1 中的图像 3,3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Fan Replacement, Disconnect the bundled cable connector: 步骤 2 中的图像 1,1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Fan Replacement, Peel the copper foil tape: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G7 Fan Replacement, Peel the copper foil tape: 步骤 3 中的图像 2,2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Fan Replacement, Remove the screws: 步骤 4 中的图像 1,2 HP EliteBook x360 830 G7 Fan Replacement, Remove the screws: 步骤 4 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Fan Replacement, Display panel cable: 步骤 6 中的图像 1,1
    • Disconnect the display panel cable from it's connector on the motherboard.
  7. HP EliteBook x360 830 G7 Fan Replacement, Necessities that help keep the fan in place: 步骤 7 中的图像 1,1
    • Remove the display panel and the wireless antenna cables from the routing channels. Then, remove the retention tape from the system fan.
  8. HP EliteBook x360 830 G7 Fan Replacement, Loosen the screws: 步骤 8 中的图像 1,1
    • Loosen the JIS #1 screws that secure the system fan to the motherboard.
    • These screws are captive.
  9. HP EliteBook x360 830 G7 Fan Replacement, Remove the fan: 步骤 9 中的图像 1,2 HP EliteBook x360 830 G7 Fan Replacement, Remove the fan: 步骤 9 中的图像 2,2
    • Once all of the connectors and screws that secure the fan in place have been removed sucessfully, you can safely remove the system fan from the motherboard.
结论
Taleb Tahous
于03/21/22注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 47
总计 698
