跳转到主内容
HP EliteBook x360 830 G7 Display Replacement
你所需要的
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: 步骤 1 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 步骤 1 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 步骤 1 中的图像 3,3
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 步骤 2 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 步骤 2 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 步骤 2 中的图像 3,3
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 步骤 3 中的图像 2,2
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 步骤 4 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 步骤 4 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 步骤 4 中的图像 3,3
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 步骤 5 中的图像 3,3
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 步骤 6 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 步骤 6 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 步骤 6 中的图像 3,3
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 步骤 7 中的图像 1,3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 步骤 7 中的图像 2,3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 步骤 7 中的图像 3,3
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: 步骤 8 中的图像 1,1
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 65
总计 1,355
