跳转到主内容
HP EliteBook x360 830 G7 Battery Replacement
你所需要的
  1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 步骤 1 中的图像 1,3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 步骤 1 中的图像 2,3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 步骤 1 中的图像 3,3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Battery Replacement, Disconnect the bundled cable connector: 步骤 2 中的图像 1,1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 步骤 3 中的图像 2,2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 步骤 4 中的图像 1,2 HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 步骤 4 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Remove the battery from the laptop.
结论
Emily Kaplan
于03/21/22注册
217 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 59
总计 900
