跳转到主内容
HP EliteBook x360 830 G7 Solid State Drive Replacement
你所需要的
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: 步骤 1 中的图像 1,2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: 步骤 1 中的图像 2,2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: 步骤 2 中的图像 1,1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: 步骤 3 中的图像 1,3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: 步骤 3 中的图像 2,3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: 步骤 4 中的图像 1,1
    • Gently pull the SSD free from the M.2 socket.
结论
Emily Kaplan
于03/21/22注册
217 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 57
总计 1,037
