跳转到主内容
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
你所需要的
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 步骤 2 中的图像 1,2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 步骤 3 中的图像 1,1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: 步骤 4 中的图像 1,1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 步骤 5 中的图像 1,1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 步骤 6 中的图像 1,1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
结论
另外一个人完成了本指南。
Ashia Lewis
于09/03/21注册
258 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 938
