跳转到主内容
HP EliteBook x360 1030 G3 Wireless Card Replacement
你所需要的
  1. HP EliteBook x360 1030 G3 Wireless Card Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 1,2 HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 2,2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the Wi-Fi and Bluetooth antennas.
    • Take note of which wire goes where, as mixing these cables will cause both Wi-Fi and Bluetooth to stop working.
  4. HP EliteBook x360 1030 G3 Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Wireless Card Replacement: 步骤 5 中的图像 1,2 HP EliteBook x360 1030 G3 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Carefully pull out the card by sliding it to the left.
结论
另外一个人完成了本指南。
Shea Charkowsky
于04/15/19注册
786 声望
创作了3篇指南
团队
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G9
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 48
总计 2,316
